Will we ever be able to shoot tethered to a computer with the x-t30?
I haven’t found anything that works. And the Fuji remote app is awful.
Does anyone have a solution? Are there any plans for Fuji to give users the option for tethered shooting with live view functionality with the x-t30?
thanks-
nb
  • 2 years later...
I am very disappointed that this camera doesn't have teather available as option, I have just recently discovered this as I wanted to use teather to take some pictures only to discover this camera does not have the feature even my old cannon EOS has teather, I hope Fuji addresses this with a software update or something
