Today, after shooting a couple shots with an external flash on (the only unusual thing I can think to have happened to it), the screen on my x70 (purchased a few months ago, 10k shutter, bought used so no warranty or anything) began acting...insane. It will flip the entire image randomly -- almost like the screen is glitching out. The controls seem to go with it -- so if it is flipped, then the up button is now the down button and so on. It also glitches hard enough to get itself stuff, with the screen still displaying an image, but it stays on when you turn the camera off -- until you pull the battery. I have no clue what could have started this, or what to do. I have done a reset -- no luck -- a firmware update -- no luck -- tried a new battery -- no luck -- and opened and flipped the screen up -- no luck. It still flickers around and glitches out.
Has anyone else seen or heard of this problem? I'm betting Fuji will inevitably quote me something very expense if I send it in, far beyond what it's probably smart to pay, since I don't have a warranty on it.
