Deal of the Day Today only, AmazonUS is offering huge discounts in storage media, including UHS-II SD-Cards. See the full list here. Green Monday BHphoto is offering several Green Monday Deals. Check out the full list here. Capture One 20…
The post Deal of the Day: Big Savings on SD-Cards… and Fujifilm X/GFX Deal Continue appeared first on Fuji Rumors.
Full Article on Fuji Rumors
