DPRTV APS-C Shootout: Fujifilm X-T30 vs Canon M6 Mk II vs Sony a6400 vs Nikon Z50
Mid-Range APS-C Mirrorless Shootout Chris & Jordan from DPRTV have posted their mid-range APS-C mirrorless shootout comparing the following cameras: Fujifilm X-T30 Canon M6 Mk II Sony a6400 Nikon Z50 So what do they say is best for you? The…
The post DPRTV APS-C Shootout: Fujifilm X-T30 vs Canon M6 Mk II vs Sony a6400 vs Nikon Z50 appeared first on Fuji Rumors.
Full Article on Fuji Rumors
