Hello everyone,
 I'm having some issues setting up strobes from HENSEL brand with my X100F. I'm using Hensel "expert pro 500 plus" two strobe set up, and it comes with a strobe transmitter (strobe wizard plus). I've connected the transmitter (which has only one contact pin, in the middle) to my fuji, but it does not work. I've tried with my film camera (Nikon F4) and it works with no problems. Any ideas? (and yes, there's a chance to use both strobes as slaves, but I'm interested in using the transmitter.
Thank you
