Last weekend, I took this long exposure of the Sunset rising over the Salish Sea from Esquimalt Lagoon, in Victoria, BC.
Fujifilm X-T3, Fujifilm XF 14mm f2.8R, Nisi 10-stop ND filter
f7.1, ISO 160, 27 seconds
    • Thanks Olaf, you are right, I did typo error by put "-" accidentally Now the software run smoothly in my PC Problem now, is the USB connection between camera and my PC is not stable, as with the same USB C to A cable I have smooth flaw with my macbook
    • Might be a problem with the folder name (special character for example) or path length (exceeding 255 characters)
    • Hey all, new to the forum. Had a question for X-Pro 2, and Fuji users in general, I guess, haha. Just got into photography this past year. I bought my X-Pro 2 secondhand back in August. It’s been a joy to use. Great condition and worked perfectly but recently (the past few weeks) I’ve been running into a problem where the camera will intermittently shut off and won’t turn back on again unless I remove and reinsert the battery. Even then, it sometimes won’t turn back on again and it’ll take a few tries to get it running again. It will also sometimes shut off and reset everything while switching between LCD/OVF/EVF.I haven’t dropped it or taken it out in extreme weather, or anything. Using fully charged, Fuji batteries, compatible SD cards, etc. Have updated the firmware, and factory reset it a few times. Just today, even, when the camera was briefly working, I tested a few shots and the shutter seemed to get stuck a few times then turn off.  I’m more than likely going to send it in for repair (hoping they actually have parts for such an old camera) but was wondering if anyone else has ever had these types of issues with their X-Pro 2? Or might have any ideas as to why these things are occurring. Thinking it could be anything from a shutter problem to an internal power problem. I have been using Urth adapters for experimenting with various manual prime lenses (not sure if that would cause any issues).  Appreciate any info! Thanks.
    • Hi, I just downloaded Pixel shift combiner software, for both mac and PC. I tethered GFX100 to macbook, did the multishot and everything flow OK, no problem. But considering to much time to wait, I copied the 16 RAW files to my PC (I think higher spec will make combining process faster), separate macbook to shoot and PC to process, but when I tried to "register jobs" to start the combining process, it can't open the folder, showing :
      tried to google, tried to change privileges as administratorm still can't open. Please help, hoping to get this problem solved as it may make my job way faster
