Found this site which has some infrared shots with new Fuji 14-80 mm.  Doesn't look like hot spots are a problem with this lens, at least at f/8 and f/11.  If I understand the hot spot issues correctly, I would infer that f/4 and f/5.6 should be okay also.
I had sold my old X-T10 infrared conversion a while back.  Looks like I will now have Life Pixel convert my X-T30.  My "regular" photography is with a pair of X-T3's.
Jerry
