 Fujifilm X-Pro3 The Fujifilm X-Pro3 has now been filmed out in the wild. You can see the tilt screen in action in the video above (as well as additional leaked images – thanks). The video starts at 1:21, where…
The post This Video Shows the New Fujifilm X-Pro3 Tilt Screen in Action appeared first on Fuji Rumors.
Full Article on Fuji Rumors
