Hi all.
i have updated my Fuji xt3 with the latest firmware 3.1
Im experiencing some issues with the camera in video mode.
mom using the Fuji xt 3 for professional work next to my ARRI Amira.
i get clips that are saved on the SD card in portrait mode and not landscape. It’s flipped when I open it in Da Vinci Resolve or QuickTime. I have done a reset on the camera and also switch auto rotation to OFF and ON ... problem does not go away...
Has any one experience the same issue??
