Why is there still no in camera support for more image aspect ratios? Why do we only get default and square?
Where is 4x5, 6x7, 8x10??
I don't want to do it in post, it takes way to long. This can't be that hard to implement when they already have 6x6.
Have been wating for this since xe2
