I can't find proper USB c adapter for audio output -Fujifilm xt30 . Suppose to be USB Type-C (usb3.1 gen1) to Φ3.5mm stereo mini-pin jack adapter cable compatible with analog audio input/output!!!but I can't find it.
    • Hy there When Im using the fan001 on the XH2s and I flipp the LCD Screen vertically by 180 degrees then the Screen flips vertically, what is good but it also flips horizontally. The clean feed on HDMI is not flipping horizontally but its also flipping if the HDMI output info display is on. When I unmount the fan then the screen flips only vertically. My firmware is updated to the latest firmware. Any ideas if there is a fix for that?
