I crest video on the xt3 and can view it fine on the camera or on my computer.  However, when I upload the video from my XT3 to OneDrive it ends up stripping the sound and the image.  So essentially nothing is left, but a file taking up space that you can’t see or hear anything.
Is anyone else having this issue?
Please let me know how I can fix this!
Thanks
