Hello,
I was wondering if anyone knows the reason behind not allowing most items from the lower setup menus.  I love the custom menu as I was used to it on my Canon but in some cases to change system settings I have to go into the menu and that takes a lot of clicks.  Is there a way around this?  If not anyone know how to add feature requests?
Thanks!
Rich
