Yongnuo 560 IV multi mode issue.
I can't find a solution to get HSS working on my GFX 100 II. I'm using Elinchrom Five flashes with the transmitter pro for Fujifilm. Both are supposed to support HSS, and everything works fine on my Canon R5 (with the transmitter pro for Canon). With the GFX 100 II, I can't figure out how to fix the issue of the shutter curtain being visible above 1/125s. I'm using the latest firmware versions for all equipment. I've tried the shutter modes EF, M+E, and EF+E. I've also set the flash mode to manual and to Auto FP (HSS), but nothing works. Has anyone else experienced this issue and found a solution?
You may have to be a little more patient. There are some recipe users stopping by now and then and some X-T50 film sim dial fans that stop by now and then as well. Hopefully, one of them will be able to help you. p.s. Welcome to the forum.
By buellwinkle · Posted
Patric I have a Four By FIve mono rail Sinar Norma. When I bougt my Fuji 50R, I bought a digital back for my Norma with mount that attaches to the lens mount on the fuji. I have no yet used it but I think it holds some interesting promise. If I rembemer it was listed on the Fuji website..... hope this helps you.... Jim -
By ruralrelic · Posted
This is probably very obvious, but I am a little confused! - Presumably, when using the film simulation dial on the X-T50, the Custom Settings need to be set at 'Nothing Serlected@' Is this correct? Thank you
