Hello, i'm new so apologies if this has been discussed already.
On my Fuji X-E2 when I have the exposure compensation dial set to 0 it will show an incorrect reading on the display. It usually shows a reading from +1/3 - +2 resulting in over exposed images. All other readings on the exposure compensation dial show correct. This happens in P, A and S.
Any suggestions?
looks like a hardware problem with the exposure dial...  the dial reports a wrong value to the camera's exposure control imo. I would send the camera to Fuji service - the problem seems to be reproducable, so they should be able to fix it.
