Hi guys,
is anyone using the Ming Thein bags? I'm curious how X-Gear fits, and how practical they are in use. I'm particularly keen on the two new ones, the mirrorless and the traveller bag. That looks like an extremely practical weekender combo. I usually take a backpack and love my Wandrd Prvke 21, but for shorter outings the mirrorless looks like a very handy bag to have and I think my normal day-bag Billingham Hadley Small actually has so much padding that I'm losing half the volume of the bag.
So, anyone?
