My XS-10 is just under 5 years old, and I use it extensively as my webcam through an elgato capture card. A few days ago, I started getting some disturbing glitches where the color and focus would degrade, and there was pulsing and flashing on the camera screen, and on my Mac screen.
I have tried to identify the problem: plugged in, and unplugged, updated the firmware, changed shooting modes, reset camera settings to factory, etc.  Unfortunately, the issue keeps coming back.
The only thing I can guess is that prolonged use as a webcam eventually cooked the board.
Any ideas on the problem or the fix are most welcome!
Edited by MGboston
Added video
Update: the camera seems to have self-corrected. 🤷‍♂️  My working hypothesis is that moisture caused it to glitch, and after drying out, it's working again.
