After changing from a X10 to a x30 - and I love the evf! - I found an original thumb rest from Fujifilm. The tr-x30 see pic.
I have never seen or found this before and cannot find a similar original thumb rest for my X100F either.
Anyone did?
Cheers, Arnold
Edited by aj55
