Hi, I currently own an X-T200 and am considering upgrading to the X-M5. I love the features it offers, but I have a few concerns regarding the autofocus performance, object tracking, and its ability to capture fast-moving subjects. Does it deliver consistent results with all Fujifilm lenses, or is the performance only optimized for the XC15-45mm kit lens? If the autofocus performance is equally reliable with other prime lenses, I would definitely go ahead with the upgrade. I have XC-35mm f:2 .
Thanks.
  • 4 months later...
AF is significantly improved on XM5, even you use old lens. I think that the result cannot be the same for all of lens because of their structure, but the AF of all lens will be improved.
