Hey there.
Got a new XT-50 loving the camera but it seems to freeze(Locks up) randomly and NOT too often. Has the latest firmware.
My fix is take out the battery. Just wondering if it's just MY X-T50? or does anyone else have this issue? I really don't want to return or exchange it if maybe this is just a firmware glitch for now. Thx
