Hello, after installing firmware 7.0, the electronic shutter with the flash does not work poperly (a half of a frame is black for shutter speed above 250ms, Elinchrom Skyport transmitter for Fujifilm). TTL and HSS don't work either. After a factory reset and restoring the configuration from a backup, the TTL option completely disappeared from the camera flash menu settings. After removing the battery and putting it back in the camrea, the TTL option is back, but does not work. It looks like the camera is not communicating with the transmitter. Does anyone have a similar experience?
Edited by Tomas Sevcik
