Hi guys,
I would like to show you some pictures I've took today in the morning while snowing in La Pedriza Nature Reserve.
La Pedriza is a beautiful nature reserve which it is located inside of the Guadarrama National Park, up north in Madrid, Spain.
Hope you will like them!
Don't forget to visit my website here: www.josecarpin.com
Fujifilm X-T2 + XF16mmF1.4 R WR  ƒ/11.0  shutter speed 0.3  ISO 200
Fujifilm X-T2 + XF16mmF1.4 R WR  ƒ/11.0  shutter speed 1/4  ISO 200
Fujifilm X-T2 + XF16mmF1.4 R WR  ƒ/16.0  shutter speed 1/9  ISO 200
Fujifilm X-T2 + XF16mmF1.4 R WR  ƒ/16.0  shutter speed 1/12  ISO 200
Fujifilm X-T2 + XF16mmF1.4 R WR  ƒ/16.0  shutter speed 1/10  ISO 200
Fujifilm X-T2 + XF100-400mmF4.5-5.6 R LM OIS WR ƒ/11.0  100.0 mm shutter speed 1/480  ISO 800
