Hi,
New user here. Just traded in my XT1 for an XT2 and looking for recommendations for a case for use when out on a boat (fishing in the tropics).
It will be stored inside an Ortlieb zip backpack, so the fully waterproof cases are going to be overkill and too slow.
I've been using ThinkTank Digital Holsters for the last few years but my most recent one, for an XT1, reacted badly to other metal on the camera/strap and the metal zipper has totally clogged up in a white, powdery mess.
I might try and resurrect it and coat the zipper in coconut oil, but I'd be interested to know what other people use.
Cheers
Dave
