Hi everyone,
New here and looking to jump into the Fuji world.
I will be purchasing the X-T2 body and narrowing down my lens selection.  I love shooting prime lenses and currently shoot 35mm in the Canon crop ecosystem.
How is sharpness/rendering/overall IQ between the 23mm f2 and 35mm f2? I am aware of the near focus issues (less than 30cm) shooting wide open but outside of this is IQ comparable between both 23mm and 35mm f2 lenses?
The 1.4 lenses are also tempting however the size/AF speed/WR on the f2 lenses seem to be fantastic qualities despite losing a full stop against the legacy 1.4 glass.
Thanks!
