FIRST TIME SHOOTING AN X-T5.
Thanks Jerry Changed both settings and it worked perfectly.
Welcome to the forum. Usually in the screen setup part, there is a setting called “Preview exp../wb in manual mode”, try turning this off. It may also be called “Exposure Preview“, it still needs to be off. Some folks additionally also turn on Natural Live View, but as always, you mileage may vary. I cannot help you with your second question, sorry about that, perhaps someone down the road can? p.s. turn it back on when not using the flash, or set a function button to toggle it on/off.
Hi I have two questions. First one, does anyone know if it's possible to brighten the LCD screen on the GFX100s when using flash, once your shutter speed, aperture and ISO are set? The screen is often too dark to focus see anything when using flash. Second question, has anyone encountered an issue with Godox AD600pro flash and focus bracketing where the flash stops after around 10 images, if so how did you get around it? It's not recycle time, I've tried long intervals and I don't have the issue when I'm using pixel shift function. Best regards.
Anche io ho avuto problemi, soprattutto con un esemplare di 45-100 che produceva un suono sibilante a frequenza variabile molto fastidioso. L'ho inviato in assistenza in Italia ed è stato sostituito con un esemplare completamente silenzioso...ma ho dovuto aspettare più di un mese per ottenere lo scambio. Il corpo macchina può emettere qualche suono quando si montano obiettivi non FUJI: uso talvolta un Pentax 645 macro ed il rumore che esce dalla macchina è lo stabilizzatore sul sensore.
