BIOS 3.10
Hello,i see a bug last BIOS. When i set manual or focus C /S.  I see struttering on LCD.  Only at 60 fps capture work fluid and good.
I has try all combination but look like a bug.  Why visual aim Need be same like 23/24/25/30 fps?
Anyway not look correctly becouse when i go check the video at 24 fps video look very good. Fluid.  The problem are Only when you take video and what you see in the LCD.
I have try change ISO,shutter frame ,how recording video format. Notting change.
Video can use Only at 50/60 fps  less Is very hard take a video when you look on LCD.
Edited by mapoett
  • mapoett changed the title to XS-10 LCD/EVF struttering on video 23.9/24/25/29 fps 16/80
  • mapoett changed the title to X-S10 LCD/EVF struttering on video 23.9/24/25/29 fps 16/80
