I appreciate clarification. I am using two cards and have set up via Save Data Setting the RAW/JPEG option. This, as I understand, should record RAW on the first card and JPEG on the second card. But right now I get RAW on both. And on the camera display screen it shows an R under both 1 and 2 cards. What I am doing wrong?
Thank you!
