Finally going through my Pirelli Challenge GT series images from the Go Pro Grand Prix of Sonoma two weeks back. Here are a few images as a teaser trailer...these are all X-T2 and 100-400.
McLaren 650S being chased by a bunch of cars...Porsche, Acura, etc.
Famous Flying Lizard Porsche team...based at Sonoma Raceway
Big bruiser Bentley
Edited by Puma Cat
