Hi everyone
New here - I have a Fuji x100s and the silver focus and aperture ring has a slight side to side movement to it, this does not effect the lens (black) inside.
You can physically rock from side to side, the outer sliver focus and aperture rings.
Has anyone else come across this issue and do they know of a fix. I have not dropped the camera or any idea how this has happened but any help will be greatly received.
May I take this opportunity to thank anyone who responds.
Robertr
