Hi All, I have found Issue after upgrade my XH2S to new firmare 5.10 + XF 16/55 f/2.8 Firmware 1.30
When I enable Bluetooth feature the App (XApp) doesn't recognise the camera and if I try to enter in some menù or switch OFF the camera it's freeze and I must extract the battery, otherwise all functions in My camera is stuck. This Issue happen ONLY with Lens 16-55 f/2.8 upgraded to new firmware 1.3, The Issue is the same with Sync Bluetooth with Air Glue (Ultrasync BLUE), I must try this procedure (activate Bluetooth, freeze and extract battery) several times, and sometimes it start to work. The workaround is to use another Lens like 10-24 activate Bluetooth and after verified all works fine with XApp switch off the camera, change the lens and put 16-55 f/2.8. If anyone have found the workaround please report to me.
This Issue prevent also to binding and use new TC Sync AirGlue, because the bluetooth is stuck and is impossible to find and binding the camera in the Ultrasync BLUE, the workaround is the same like above.
