Hello,
I have own a XT-05.
I have bought this adapter to use Canon Lenses
Fringer EF-FX Pro III Autofocus Adapter for Canon EF Lens to FUJIFILM X-Mount
I want to ask that if i buy Canon Teleconverters - will they work with this adapter?
The question may sound little stupid as i am new to Fuji Ecosystem.
Thanks in advnace
