I'm very new to Fuji and to my X-T5, after many years of Nikon shooting, and I'm loving it. I do have a question, though, about something strange that's going on when I use the FujiXWeekly Portra 400 V2 recipe. Attached is an example, cropped from the original image. Any ideas what's causing the weird concentric circle banding? My uneducated guess is that it might have something to do with the DR400 dynamic range setting. The raw file, of course, looks fine but the JPEG has these bands.
