Hi everyone,
My sister has asked me if I can video her wedding ceremony on Saturday.
I have s Fuji X-S10 camera body and the Fuji XF 33mm f1.4 R LM WR lens.  I also have a Sony RX100 V.
It will just be on a tripod and left to record so a couple of guests that can’t make it will be able to see the ceremony.
Having never really used the video function of either camera I have no idea what settings to use or if I will face any issues
The ceremony will be about 30 - 40 minutes and I want to press record and leave it going.
Any thoughts on which camera I should use?
Will one battery suffice?
What video settings should I use?
what size memory card will I need?
Thanks for any assistance & advice
