I bought the XS-20 camera with the 18-55mm lens. This lens is great for photography but I need a wider lens for vlogging, so I'm looking for the best vlogging lens for it. I've been thinking of:
- Tamron 11-20mm F2.8
- Viltrox 13mm F1.4
- Fujifilm XF-8mm F3.5
I was wondering whether anyone could help me make a decision, I'm torn between these 3.
