I have a new xt10 and am considering some sort of grip enhancement. My problem seems to be that when gripping the camera, mainly one handed, my thumb pad hits and sets off the selector function buttons interfering with my photo taking etc. In order to keep pressure on the thumb rest, my hand is forced into a position that causes this. Would a thumb or body "gripper"by itself remedy this or would both together be needed? Anyone else have this problem? Thanks for your input re-this .
