Despite best efforts, I can't seem to turn off automatic image review on my 50R. This is despite IMAGE DISP being set to OFF in the setup menu, and occurs no matter which view mode I'm in - the shot taken is always displayed for approximately 0.5 seconds. Interestingly, even when IMAGE DISP is set to CONTINUOUS, the image is displayed for about 0.5 seconds.
It may be my imagination, but I seem to remember having successfully set the camera to not automatically review images at some point, but if I did, I don't know how I did it. Any thoughts?
