I just bought the XE-2 with the kit lens, both used. I find the lens to be quite sharp, good color and contrast. It focuses quickly and I am not dissatisfied with it in any way. I've hardly ever manually focused (I never see the need to) so I can't advise you there other than to see I've had no issues.
The XE-2 has a control dial beneath your right thumb. When you press it, you can see a highly magnified view which greatly aids in focus confirmation or manual focus. It's quite handy.
This is my first mirrorless camera and it has reignited my love of photography. I've since purchased four prime lenses and am looking to add a tele zoom.
Go for it, I say.
Edited by Tommyboy
Here's a recent portrait of my daughter. It's just a snapshot, really, but I was very impressed with the sharpness and the bokeh. For the price, it's a pretty sophisticated lens—outmatching any of its competitors and it's a 2.8 to boot, for part of its zoom range, anyway.
