Would really appreciate the help!
I have a new XT5 and since I mostly shoot with vintage lenses, I like labelling the shots taken with the right lens infos for post processing and always did fine with my older xt10 but on this one it doesn’t seem to work?..
I obviously have "shoot without a lens" switched on and all 6 custom mount adaptor settings customized in the MY MENU section for both name and focal length but when I take pictures, I can’t see the lens info on the shot in the playback ?
Why?
And also is it possible to add more than 6 custom lenses?
