Hi all! I am trying to decide which telephoto to buy for the XT4 for wildlife photography. I am going to Costa Rica soon and plan to travel a lot with the new Lens so size and weight is an important consideration. What do you think about the Tamron 150-500? I like that it has more reach than the Fuji 100-400. The new Fuji 150-600 looks great but it is bigger in size and would require me to get a new camera bag. The Tamron 150-500 seems like a happy middle and is cheaper than both. I figured that the image quality would be great on all of them. What do you think?
