Good morning, in my Fuji I set different settings in the options C1, C2 etc. of the Q quick menu
Everything works except the image stabilizer functions, although the set disabled in C1 and enabled in C2 is not stored and always remains at the last setting entered.
can anyone help me? Thank you
