In Canada Fujifilm has organized Fuji Photo Walks with the FujiGuys From Vancouver - Calgary - Ottawa - Toronto - Montreal
It looks like Fujifilm USA is starting Photo Walks in some cities as well...
https://www.instagram.com/fujifilmx_us/
Fujifilm X Series US
The Official Instagram of X-Series USA The Soul of Film in a Digital World ❤ We'll remind you why you love photography. #FujifilmX_US www.FujifilmXSeriesUSA.com
From Boston Fuji Photo Walk...
Edited by ericdraven
