Hi,
I am Shafaat from Bangladesh.
I have bought a X-M1 with Kit Lens XC 16-50mm and now the "lens signal contact" is broken. The lens does not stay with the body anymore and am not able to turn on the camera as the body cannot sense the lens. Pictures have been uploaded.
Need help which specific part(s) I need to buy and from where can I buy it from and how much it may cost me.
Thanks
Shafaat
