Hi,
I've set my fuji x100v to aperture priority mode (both SS dial and ISO dial set to A and aperture ring set to f2)
Every now and then it jumps into manual mode for a second or two and then goes back to AP mode. This also happens when I'm in the menu which then makes the menu turn off.
Any ideas?
