Hello, I have recently bought used X100T, everything appears to be working fine but today I noticed that the lens is off the center.. do you have any experience with this and can it cause any problems?
The camera is slightly scratched but if it is only cosmetic I’m fine with that. I can still return it and it has warranty for hidden problems.
