On my new X-T4 I loose Shutter prioity mode.  I haven't been able to repeat the exact steps, but it would appear to be when I go into some menus, without necessarily changing anything.  I need to reset to default settings to find it again.  Anyone found the same problem or has a solution?  Thanks for your help.
