I'm trying to use this edelkrone follow focus to work with my xh1 and the 18-55. However, when the tension gets too harsh, the camera body moves slightly away from the battery grip (which is fixed on the cage). Resulting in overleaping a tooth on the gear wheel. I'm beeing very cautious, trying not to force but it happens anyway...
Any suggestions how to fix that? Or is it just so you should not use a follow focus with this system?
