Hi guys,
I have watched every youtube videos and read every forums, didn't find any answer.
I can't use HSS on my godox DP800iii with my GFX100S, 120mm macro lens. I use a XPROF trigger that supports HSS (it shows the HSS pictogram, sometimes).
I tried the same set up with my old nikon D810 and HSS works fine.
I put GFX100S in TTL, Mechanical shutter, I can put faster speed, but when I shoot, the flash doesn't work. If I push test button on trigger it works…
Does anyone has an idea ?
Thank you
Ben
