Hey
I have a big problem I noticed 2 hot/stuck pixels on my fuji xs10 and did Pixel Mapping and it fixes all my problems in Photography but not in Video it seems like Pixel Mapping does nothing for Video because exactly that 2 white pixels are at the same place but just in video mode ad photo mode there is nothing! hope there is a fix
Thanks
  • 8 months later...
Second this! I have an X-T3 with many hot pixels (6-10) that are present in 4k video mode and won’t go away with pixel mapping. They are definitely not “dead” pixels as they are bright and do react to light. Is there a secret “auto black balance” for video in the Fuji system like in many video cameras? Help!!
