Hallo,
just bought second hand x-t3 and I'd like to ask somebody more experienced about P mode behavior.
My x-t3 (+ 35mm/1.4) in P mode chooses strange combinations. ISO is fixed (200). X-t3 chooses very low appertures (1.8, 2, 4) and short times (800, 1800) , I never got apperure > 5.6.
I have also x-t20 and it works differenly, let say in more standard way.
Is this normal behavior for x-t3?  Don't you know whether the algorithm is described somewhere?
(I have latest firmware for body and lens and I tried factory reset).
Thanks for any advice.
