When I move my SS to T-mode and set it to any value (e.g. 20 seconds, 30 seconds) the shutter is not staying open.  It is taking a picture at around 1/30th.  The camera seems to work fine at all of the other dial settings except T.  Anyone else experience this?  Is there some other setting preventing a long exposure?
Thanks in advance!
Edited by Rob Seymour
typo
  • Rob Seymour changed the title to X-T3 - Shutter Speed in T-mode Problem
